DQL timeseries: aggregate data based on lookup fields
I’m trying to group a timeseries based on new fields I fetch after a lookup.
So basically, I’m fetching a timeseries (here dt.kubernetes.node_conditions). Then, I lookup the kubernetes nodes to get a specific label and the managementZone.
After that, I would like to group the timeseries based on this label and the management zone.
For example:
timeseries avg(dt.kubernetes.node.conditions), by:{dt.entity.kubernetes_node}, interval: 10m
| lookup [fetch dt.entity.kubernetes_node], sourceField:dt.entity.kubernetes_node, lookupField:id
| fieldsAdd node_type = lookup.kubernetesLabels[`kube/nodetype`], managementZone = lookup.managementZones
I didn’t find a way to group the timeseries avg(dt.kubernetes.node.conditions) based on these new fields.
Is it something possible ?
Hello @Adrien_Z , what kind of output are you expecting ? A time series or a single scalar per node_type (or managementZone)?
I want a time series per node_type that will represent the sum of the timeseries of all nodes having this node_type.
for example:
node |avg(dt.kubernetes.node.condition)|node_type
nodeA|1,1,,,1 |typeA
nodeB|,1,1,1, |typeA
Result: -->
node_type|avg(dt.kubernetes.node.condition)
typeA    |1,2,2,1,1
Let me know if you need more information
Thanks for the additional information, this will be possible with an enhancement that will be delivered this year. I will revert with the syntax once it is made available.
Thank you for the information.
I’ll wait for the update of this tread
I would need this feature too. Since 2023 is over, is it possible now to do so?
thanks
It is possible right now. Using the initial example it would look like time:
timeseries cond=avg(dt.kubernetes.node.conditions), by:{dt.entity.kubernetes_node}, interval: 10m
| summarize {cond=sum(cond[])}, by:{node_type, managementZone, interval, timeframe}
-Kris
Thanks, it work fine, even if I would never find the solution without your help. The sintax is not really simple
For future reference:
Example 6
Thank you. It is working now and thanks for the example.
thanks for the example, it helped me in parts.
Seems the result above comes in a table. Is there any way to timeseries the data again?
Nevermind, with the example provided did work. I don’t know the reason it was not working before.
