Summary
Dynatrace Assist now communicates over WebSockets. Customers whose networks use strict proxies or firewalls that block or interfere with WebSocket traffic will see problems when using Assist.
Problem
Assist errors, connection failures, or Assist not responding in strict network conditions.
Resolution
Make sure network policies allow WebSocket connections to wss://*.apps.dynatrace.com.
If a stricter rule is required, allowing the /platform-reserved/ai/v0.1/operator:chat path is the minimum viable way to allow Dynatrace Assist communication.
What’s next
Opening a chat or support case
If this article didn’t help, create a chat or open a support case
- Mention that you reviewed this article.
- Include the following details:
- Screenshots of the errors seen in the Dynatrace Assist UI
- Approximation of timing when the errors appeared
