Dynatrace certification Exam - Schedule availability
Hi everyone,
I would like to know if it is possible to take a certification exam at night hours during the week or weekends? Or does it strictly have to be working hours?
Thanks in advance
I just looked and it appears that you can.  I would suggest logging in and confirming for yourself.
Hi @olivar1995
While Scheduling the exam you will get prefilled dates. Just choose from them which will be suited for you(Night Hours).
Make sure the timezone is matching with where you currently are, just to avoid some confusion.
Thanks & Best Of Luck.
I have already checked and yes it is possible to schedule at night and even on Saturdays. Thank you very much for your help
