Yes you 'll need to change the level of the PLT program ZDTPLT according to the level of CICSTS.
for CICSTS 5.4, the corresponding PLT program is ZDTPLT72.
But there is an easier way to process.
Mention in the PLT Table the alias program called ZDTPLT only, then in your library or DFHRPL, the associated program will be choosen according to your CICSTS level .
Example :
DELIM DFHPLT TYPE=ENTRY,PROGRAM=DFHDELIM
DFHPLT TYPE=ENTRY,PROGRAM=ZDTPLT DYNATRACE
DFHPLT TYPE=FINAL
END
