Hi Team,
I have been asked below question by customer. Could you please help me with the clarification on the below questions?
- Is there Oracle plugin available to suggest query optimization?
- Does dynatrace integrate with Greenplum and postgres?
- There is a ServiceNow integration with Dynatrace, as part of that, is there ServiceNow dashboard WITHIN Dyatrace that is available to use?
Thanks&Regards
Srinivas
Hey Srinivas,
1. we support multiple oracle technologies. Can you please tell me what is the oracle (DB, CRM etc..) solution area you are looking for?
2. Dynatrace does provide an integration into PostgreSQL out of the box: PostgreSQL extension — Dynatrace Docs. Greenplum is not on our radar yet, but we would appreciate if you could elaborate on your use case a little bit and maybe submit a product idea for us to evaluate.
3. We do cover 3 areas/use cases for our service now integration:
a. Incident Integration
b. CMDB Integration
c. Events Integration
You can find out more about the integration and setup here: Send Dynatrace notifications to ServiceNow — Dynatrace Docs
The same question would apply here, what type of dashboard are you looking for OOTB for this integration?
Cheers,
Paul
Hi Paul,
Thank you for the response. I will get back to you on Greenplum use cases and SNOW dashboards after checking with customer.
Thanks&Regards
Srinivas
