Dynatrace Managed Node Shutdown Time?
We have five node Managed in 1 cluster Dynatrace. How much time can stop all service in one node?
Hi @xuyenpn
It all depends on the load on the node in question. As a rule of thumb, as I observe on my environments, it can take up to a few minutes.
Radek
I mean downtime for one node in cluster five node?
Yes, I also referred to the exclusion of one node in the whole, cluster. Remember that DT has to shut down connections, redirect traffic etc. This takes a while.
I want to shutdown 1 node within 2 days. After that I will turn on it. Does it work normally?
Yes, if the other nodes are working correctly then the whole cluster should not be affected.
Yes, thanks you so much!
