I have been using terraform helm_release to deploy the dynatrace operator for quite a while with no issues. I am now trying to add env vars to the oneagent pod but am getting an error about using a string when I try to apply vars. Below is the code and error. This is version 0.4.2. Also, for reference I had no problem passing in:
set { name = “classicFullStack.args” value = “{--set-host-group=${local.eks_cluster_name}}” }
Problem code in question: (I have tried this with just “”, [“”], without “”
set { name = “classicFullStack.env” value = “{DT_DEBUGFLAGS=debugExtensionDSstatsdacceptremotestatsdtraffic=true}” }failed: DynaKube.dynatrace.com “dynakube” is invalid: spec.oneAgent.classicFullStack.env: Invalid value: “string”: spec.oneAgent.classicFullStack.env in body must be of type array: “string”
