Dynatrace Topology Model
How to associate 2 metrics on Dynatrace and show the other as an anomaly in the problem window when a problem occurs in one. For example, I want to associate ‘(builtin:host.disc.usedPct)’ and ‘(builtin:host.cpu.usage)’ metrics. If an anomaly occurs on 2 metrics, can I see this relationship on the same problem window?
I created metric event in two metrics
Best Regards,
Kadirhan Cekmez
If both problems relate to the same host-entity the DavisAI should merge the problems into one; unless you created static-Anomaly-Detection rules in which case you need to ensure the merge toggle is enabled in AD settings page.
