Elapsed time for processes
Is there a option for monitoring elapsed time for job, processes in linux?
We need to discover a zoombies jobs and processes to apply some command to stop.
In the explorer data it is not posible to see.
Can you explain o show me how?
Hi @Jachavez,
I think there is not a bulit in function for it.
I would try two things :
1. Check this feature at linux part (maybe failed status can be used). OS services monitoring | Dynatrace Docs
2. Write a custom one agent extension for this special requqest. OneAgent extensions tutorial | Dynatrace Docs
Maybe other community members have better ideas.
I hope it helps.
Br, Mizső
