Email Notification for Web Errors
Hi all,
Can someone help if Dynatrace supports email notification if Web Application encounters errors?
Example, WebApp encountered http 500 errors for 10 consecutive then will send me an email.
Abner Jr.
While this might not be out of the box for a set of 500 errors in X amount of time, but you can create a metric event (Custom event for alerting) to accomplish this.
You can also create a metric if needed via the multi dimensional analysis and then have that set to alert via the metric events. the possibilities are endless :slightly_smiling_face:
