[Dynatrace Managed]
In the Cluster Management Console I have configured a smtp connection with a sender email address, e.g. noreply@mydomain.com [Home → Settings → Emails → SMTP server]
Cluster Management emails come through my smtp service and are received from this sender email address.
In my Environment, there are no settings for sender email address. [Settings → Integration → Problem Notifications → Set up notifications → Email]
Problem notifications coming through this integration seem to be going out to Dynatrace Mission Control and are received from an external address 'notifications-noreply@dynatrace-managed.com’.
Can we configure integration/email/problem-notifications to use the cluster smtp connection, and use the sender email address configured therein?
Not that I am aware of, I’d recommend tossing in a RFE for this tho.
I’ve converted this to an idea.
Here is a better problem statement:
[Dynatrace Managed]
Problem notifications going to an email integration go external through Mission Control, then back to the emails recipients I have set. This raises privacy and confidentiality risks for the information in my notifications.
If the email integration was revised to use a configurable smtp connection, then I could send these problem notifications internally, avoiding any hops outside.
The cluster notifications have configurable smtp connection…
Hi I’ve converted that to the question
Your expectations are right. If you configure SMTP server for notifications this configuration should be used. So problem notifications should come “from” exactly same address as you configure in CMC.
E-mail notifications will come via Mission Control and “From” address will be converted and enforced to 'notifications-noreply@dynatrace-managed.com’ only if the SMTP server cannot be reached (as a fail-back). That needs to be investigate - I’d go with a support case here. If everything is good at your side, then it’s a bug in Dynatrace - support case is appreciated here as well
Hope this helps!
Hi Radoslaw - thank-you very much for the advice. You are correct, the problem notification will use the CMC configuration. I ran another test and confirmed this.
It’s embarassing now, but I had configured the CMC smtp on our cluster and inadvertently was testing the problem notifications on a separate proof-of-concept system that didn’t have the CMC smtp config.
Dear Richard,
Have you got the solution for this issue?
