Enablement and cost control global vs. web/mob/custom
Dear All,
As the granular configuration always takes precedence on the global level settings.
Is this the same applicable to enablement and cost control? if NO
What is the benefit of global configuration in case of multiple applications?
How can we effectively use the enablement and cost control global configuration when each newly created application captures and analyzes 100% of user sessions (instead of configuring each application)?
Babar
Hi.
There’s precedence as in other settings.
In terms of use cases, I can imagine a situation where you always start with 10% of user sessions instead of 100%, to check if the application works as expected. Later on you can move to 25% - 50% - 75% - 100%.
