How can kubernetes event visibility be enabled by default for all clusters or can it only be enabled individually for each cluster via the web interface ?
Thanks.
Thanks.
This should be converted into an idea… We should be able to control the cluster configs directly via Operator/dynakube yaml.
@PaulE, you can edit the “Monitor event” config via API Settings API - PUT an object — Dynatrace Docs
schema: builtin:cloud.kubernetes
field: eventProcessingActive
I was looking for a way to enable for all clusters and didnt want to enable each one individually.
