Error Alert on 3xx response code
Hii,
Is there any way to trigger email alert on  3xx response code of api.
thanks
Prithvi
Hello @Prithvi_Mandal
You can achieve this through:
  • Configuring Synthetic monitors and add the fail if criteria
BR,
Peter
Hii @Peter_Youssef ,
actually API’s has already monitored in our environment. how can we do without synthetic .
Regards
Hi @Prithvi_Mandal
you should do it in 2 steps:
1- Create a calculated metric on your API to count the number of http code 3xx.
2- Create an Event metric based on this Calculated metric and trigger and event when you reach a specific threshold.
BRs,
Hi @Prithvi_Mandal
There is a way you can create multidimensional analysis view and create a metric based on the error.
BR,
Peter.
You have another solution to create request attribute as per the attached example and then configure the required alerting
Under custom rule select the request attribute which will be either based on the response code 302 or the http method “Get”.
Tip:
  • To proceed with this alternative solution, you have to create a request attribute based on the http method and Response code, then you will be able to create the required metric and receive alerts upon occurrences.
  • Request attribute.
KR,
Peter.
