"Error making post request to Dynatrace API: Post"
I’m trying to setup Dynatrace for my EKS Fargate, all 3 Dyntrace pods are in running state, but when I try to apply the OneAgent manifest and describe Dynakube, I notice this error. Does anyone know how to fix this please?
Last Transition Time:  2023-05-24T19:32:56Z
    Message:               error making post request to dynatrace api: Post “https://{environmentid}.live.dynatrace.com/api/v1/tokens/lookup”: read tcp 10.xx.xxx.xxx:55736->34.xx.5.xxx.28:443: read: connection reset by peer
    Reason:                TokenError
    Status:                False
    Type:                  Tokens
  Dynatrace API:
    Last Token Scope Request:  2023-05-24T19:32:56Z
  One Agent:
  Phase:  Error
  Synthetic:
Looks like the token lookup is failing, it is checking the token for necessary permissions.
You can try this check manually with this call
curl -X 'POST' \
  'https://{your_endpoint}/api/v2/apiTokens/lookup' \
  -H 'accept: application/json; charset=utf-8' \
  -H 'Authorization: Api-Token dt0c01.5VXCARPRP52BZNJVBUDSMQA5...' \
  -H 'Content-Type: application/json; charset=utf-8' \
  -d '{
  "token": "dt0c01.5VXCARPRP52BZNJVBUDSMQA5..."
Check for necessary permissions here
We are good from token perspective, it has all necessary permissions but somehow it still get failed
Please try following steps and check for any errors in the output.
I
Is it normal to not have OneAgent here? as you can in my network zone i have 1 ActiveGate but not OneAgent.
I’m trying to set up dynatrace for eks cluster with fargate
If token check fails there will be some communication issues, please check troubleshoot output command.
Open https://{environmentid}.live.dynatrace.com/rest-api-doc/  Maybe that makes it easier to test API calls and observe the output? It’s sort of swagger
What deployment method did you use? We use Argo with to deploy the dynatrace operator (helm chart) and a self made helm chart for the dynakube.yaml custom object. This should autoconfigure at least 1 Activegate and for each node there should be a oneagent.
I do have Argocd but i didnt use it for dynatrace manifests deployment. Could you please share all your dynatrace manifests to be deployed with Argocd?
Yes; I can share some info in a few days I think
I have shared some details with manifests to give you an impression how to do it.
dynatrace_manifests.txt (9.02 KB)
Hi kwatatsh
How you fixed the “https://{environmentid}.live.dynatrace.com/api/v1/tokens/lookup”: read tcp 10.xx.xxx.xxx:55736->34.xx.5.xxx.28:443: read: connection reset by peer" error.
We also having same issue.
Could you suggest pls
You have to set a proxy for your dynakube (ref applicationMonitoring.yaml)
Just uncomment proxy and skipCertCheck
proxy:
value: http://<put your proxy here>:port
and set
skipCertCheck: true
