After Activegate rotated to a new AWS ec2 instance and upgraded to a new version I am getting this error . Kindly helpto resolve.
Failed to assign monitoring configuration to ActiveGate. Reason: Fast check failed for 1 endpoint(s). Cannot connect to database jdbc:sybase:Tds:10.39.0.131:2322?ENABLE_SSL=true&SSL_TRUST_ALL_CERTS=true&ENCRYPT_PASSWORD=true&CHARSET=iso_1&CHARSET=iso_1&DYNAMIC_PREPARE=false. Exception occurred: Error when adding connection management layer to datasource - JZ028: Illegal value set for JCE_PROVIDER_CLASS connection property. The property value must be a fully qualified provider class name passed as a String or an instance of java.security.Provider. [SQLState: JZ028].
