# Essential parts of Dynatrace for migration
**URL:** <https://community.dynatrace.com/t/essential-parts-of-dynatrace-for-migration/38375>\
**Category:** Upgrade To Saas\
**Tags:** upgrade-to-saas\
**Created:** [February 10, 2023, 7:38am UTC](https://community.dynatrace.com/t/essential-parts-of-dynatrace-for-migration/38375 "2023-02-10T07:38:36Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![MaciejNeumann](https://avatars.discourse-cdn.com/v4/letter/m/5e9695/32.png) [@MaciejNeumann](https://community.dynatrace.com/u/MaciejNeumann)\
**Post date:** [February 10, 2023, 7:38am UTC](https://community.dynatrace.com/t/essential-parts-of-dynatrace-for-migration/38375/1 "2023-02-10T07:38:36Z")
</div>
Can you recommend what parts of Dynatrace are most essential to migrate to reduce the migration time to a minimum?
**Author:** ![Radoslaw\_Szulgo](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/radoslaw_szulgo/32/1977_2.png) [@Radoslaw\_Szulgo](https://community.dynatrace.com/u/Radoslaw_Szulgo)\
**Post date:** [February 14, 2023, 11:58am UTC](https://community.dynatrace.com/t/essential-parts-of-dynatrace-for-migration/38375/2 "2023-02-14T11:58:06Z")
</div>
As always - it depends. Based on the upgrade plan and target architecture in Dynatrace, execution of the upgrade moves all Dynatrace monitoring of workloads from the on-premises Dynatrace Managed environment to the Dynatrace platform:
- The Dynatrace environments are created in one of the available regions.
- All configuration is applied to the Dynatrace environment (either through automation or manually applying the necessary configuration to the SaaS environment).
- Dynatrace components are moved (OneAgent) or replicated (ActiveGate) to the new Dynatrace environment.
- Monitored applications are restarted to ensure that all monitoring is moved to the new Dynatrace environment.
To reduce the migration time to the minimum, leverage automation tools - such as [Configuration-as-code](https://www.dynatrace.com/support/help/setup-and-configuration/configuration-as-code) and OneAgent automation capabilities - such as [orchestration packages](https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-oneagent/deployment-orchestration) or [oneagentctl](https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-oneagent/oneagent-configuration-via-command-line-interface).
The most common parts that are migrated:
| Network Zones | User Groups | SSO Setup |
| Management Zones | Tagging Rules | Naming Rules |
| Custom Services | Services Configuration | Extensions |
| Synthetics | Cloud Automation | Process Group&nbsp;Detection |
| Application Definitions | Deep Monitoring Settings A | Log Monitoring |
| Anomaly Detection | Alerting Profiles | Dashboards |
| Notifications & Integrations | Maintenance Windows | SLI/SLOs |
| API Tokens | Credentials Vault | Mainframe Volumes |
| OpenTelemetry | Cloud Platform Integrations | Custom Metrics |
