etcd_server_has_leader was not found error
Hello.
I’ve tried to use and implement some extensions for openshift like openshift control plane, kubernetes persistent volume claims. And they worked as i expected with no problem.
But when i’m trying to install and configure etcd for openshift extension, after waiting 10-15 minutes, when i go to related dashboard i just see Metric etcd_server_has_leader was not found.
Do you have any idea about what im probably doing wrong or what i’m supposed to do?
Hi @kasdev,
Have you already installed the the dynakube operator to the master nodes also? I think this extesnion will work in that case only. I do not use this extension because we use a nodeselector in the custom resource yaml:
nodeSelector:        “node-role.kubernetes.io/worker”: ""We have only information about the master nodes via the kubernetes api integration.I hope it helps.Best regards,Mizső
