Events Mechanism
Hi there,
I was wondering if it is possible to disable certain types of events on my managed cluster. Lets say for instance that I have an environment just for test and I want to integrate just CONNECTION_LOST event type to an external tool.
Can I configure event generation to create just some event type instead of many other types too?
Thank you.
Alexandre França
Note: I want to do this on event level, not problem level.
No, there is no way to influence the event generation, aside from modifying the anomaly detection settings, which does not include options for all event types though.
