Exclude Specific Browsers From Query Results
We use the following query in Data Explorer to monitor LCP:
builtin:apps.web.action.largestContentfulPaint.load.userType.geo:filter(and(or(in(“dt.entity.application_method”,entitySelector(“type(application_method),entityName.equals(~“loading of pdp~”)”))))):splitBy(“dt.entity.application_method”):percentile(95.0):sort(value(percentile(95.0),descending)):limit(20)
Is it possible to modify that query to exclude LCP data from the “FacebookBot” browser?
I would say no, as you can see, browser is not a metric dimension:
Best regards
Yes, for me Browsers is a dimension:
Yes, I was checking another metric. Which options appears to you in filter field?
Is not there?
Best regards
Yes, I can filter by browser. Many different types of browsers are available for me to filter the results by.
My question is how can I exclude one of those browsers from the results. For example, how would I write my query to retieve and trend LCP metrics for everything EXCEPT the “facebookbot” browser.
You will need to adapt the query and negate the browsers you are not interested in, here an example:
builtin:apps.web.action.largestContentfulPaint.load.browser
:filter(
    and(not(in("dt.entity.browser",entitySelector("type(browser),entityName.in(~"Chrome 100~",~"Chrome 101~",~"Chrome~")")))
:splitBy("dt.entity.browser"):sort(value(auto,descending)):limit(20)
I see your point. @mark_bley has already pointing you in the right direction. You need to use “not” to exclude it.
Best regards
Perfect. Thank you!
