How can I see the execution plan for a SQL server with OneAgent deployed?
Hello Juan,
To view the execution plan metrics you will have to go to databases → select your MS SQL server and click SQL details and Further details tabs to gather the information you need.
Here is a link that explains more. Take a look at the compilations, recompilations and process block metrics: Microsoft SQL Server extension — Dynatrace Docs
David Nicholls
