experience score Export - query Mgmt Zone and/or custom tags?
All,
I need to export user experience score data per application.  I need to only pull applications for a particular management zone.  We also have a custom tag on these applications that I could also use as a key if it’s available to query.
However, I do not see a parameter I can use in my query.  In order to export to JSON I am using a CURL command, so I cannot use the Filter via the UI for Management zone.
Let’s say the Management Zone is “NA” for North America.  How can I add that to the query?
Here’s my query:
select count(*), useraction.application,userExperienceScore FROM usersession group by useraction.application,userExperienceScore order by useraction.application ASC
Thanks!
John
So I recommend doing an API pull for that and not use the USQL. Environment API v2:
