Use case: Enabling filtering and filter bars to entity lists of screens created from an Extension 2.0 YAML.
Example context: I have an entity type “my:interface” that has a RUNS_ON relationship to an entity type “my:device”. I have an Entities List card which already lists all “my:interface” entities I want to filter.
All definitions are given based on schema version 1.239 and may or may not change in the future.
Example 1: I want to filter my list by the interface names.
YAML definition:
filtering:<br> entityFilters:<br> - displayName: Interface<br> filters:<br> - type: entityName<br> displayName: Name<br> freeText: true<br> modifier: contains<br> defaultSearch: true<br> distinct: false<br> entityTypes:<br> - my:interface
YAML explanation:
- filtering - the block which defines the filtering capability
- entityFilters - the block which defines the groups of filters (these are displayed slightly greyed out in the filtering list)
- filters - the actual filters that are part of this group
displayName - how this filter is labelled within the UI
type - must reference an attribute of the entity you are filtering. Note: every entity has entityName as a default attribute.
freeText - if true, the user can freely type text; otherwise they must select from a list of suggestions. Note: only default attributes such as entityName are capable of offering list of suggestions.
modifier - when freeText is true, this defines how the text should be matched against the attribute. When freeText is false, this must be omitted. Note: all non-default attributes must match as “equals” regardless of this option.
defaultSearch - when true, if the user starts typing without selecting a filter first, this filter will be selected by default. Only one filter within the filtering block may have this enabled.
distinct - when true, only one instance of this filter can be applied
entityTypes - A mandatory list of entity types that this filter applies to. If you omit this, your filtering bar will just show a spinning wheel because of the incomplete definition.
Example 2: Given example 1, I also want to filter by the device these interfaces are running on
YAML definition:
filtering:<br> relationships:<br> - type(my:device),toRelationships.runsOn($(entityConditions))<br> entityFilters:<br> - displayName: Interface<br> filters:<br> - type: entityName<br> displayName: Name<br> freeText: true<br> modifier: contains<br> defaultSearch: true<br> distinct: false<br> entityTypes:<br> - my:interface<br> - displayName: Related entity<br> filters:<br> - type: entityName<br> displayName: Device name<br> freeText: false<br> defaultSearch: false<br> distinct: true<br> entityTypes:<br> - my:device
YAML Explanation:
Most of the definition is the same as above. Changes include:
- filters
- entityTypes - For the second filter, this is now “my:device”. This is because despite filtering a list of interfaces, the filter attribute belongs to devices.
- relationships
- any entity that is not directly part of the entity list must have a relationship defined to the listed entity for it to be considered. $(entityConditions) here resolves to each of the “my:interface” entities.
