Dear All,
Which Dynatrace cluster version support the EEC? Until, 1.246.192.20220811-230403, I did not find this feature.
Babar
Hi Babar,
Our clinets managed servers were upgraded in the past two days to 1.248. You can find it from this managed version. I do not know what is the default set (on/off) of it becasue I found enviroments with both state in the same managed enviroments. One of our clinets MS-SQL extesnion did not work without this setting.
Br, Mizső
