I am trying to filter a settings/object API call via the filter parameter on the “value” field. The REST API docs mention it is possible to filter by subproperties, but this is unable to parse characters like - and [].
Example:
{tenanturi}api/v2/settings/objects?schemaIds=builtin:logmonitoring.log-storage-settings&scope=scope&fields=value&filter=value.config-item-title=‘test’
and with filter=value[“config-item-title”]=‘test’
same error on token recognition error at: ‘[’"
Follow up question:
Given this is the structure of the value field in a settings object
Would it be possible to filter the response by the content of the matchers field?
For instance, returning only settings that contain log.source matchers?
Thank you for your help ![]()
