I am trying to Filter Dashboard data using Generic tag key, I have a K8 cluster with multiple application on diff namespaces, I have introduced tags for the same.
While filtering dashboard data using tags I am facing issues, if the tile is made using advance query in data explorer, the data is not reflecting as expected, can anyone kindly help here :).
I am using this query in data explorer : (builtin:kubernetes.node.requests_cpu:last:splitBy(“dt.entity.kubernetes_cluster”):sum / builtin:kubernetes.node.cpu_allocatable:last:splitBy(“dt.entity.kubernetes_cluster”):sum * 100):sort(value(sum,descending))
When adding this tile to dashboard, I am making the following dashboard config for tag.
I maybe found the reason/solution - > I recognized the Entity types affected by tag + Add entity type button. And after I added entity type “Service” and “Request” the dashboard started to filter (manually tagged) key requests
