Hi there, How do I get the count of applications with Synthetic problems?
best regards,
Rajesh
best regards,
Rajesh
I would recommend you set the synthetic to alert when there is an outage or issue from the outage settings:
Then Create an automatic tagging rule that tags the Synthetics with the Application name. This will allow you to filter and sort the problems via the problems tile and get you the numeric that you are looking for.
