Allthough it’s mentioned in RFE : CrUX metrics, and visible in details of the Contributors breakdown graph ((K) in below image), I can not pull the first contentful paint (FCP), metric with the USQL, not use it in a custom chart.
The Time to first byte (TTFB) can be used in a custom chart, but is not found in the USQL either?
If this is by design, are there plans to make this available or are there reason not to?
