Gemfire monitoring Dynatrace
Hi all,
please help, is Gemfire cache manager supported by dynatrace ?
can we monitor it via a specific JMX extension, if yes what is it ?
Regards
Direct monitoring via OneAgent is not possible.
You can use the built-in JMX extension to extract the required parameters. On the GemFire side, you need to run the JMX support (Starting a JMX Manager).
Please note that such an operation consumes DDU licences.
Radek
