Hi everyone.
This question is not so much related to Dynatrace itself but more to expanding the knowledge around it. Many clients I have also use Kubernetes and while I have knowledge on how to integrate/dashboard it in Dynatrace, I would like to gain more Kubernetes knowledge. While I have seen this and that, I am searching for a beginners course to make sure I am missing no information and understand the entire set up. Does anyone know very good, but affordable options? Maybe also with a recognized certificate in the end (or at least leading up to one)? Bear in mind that I don’t want to be busy with Kubernetes full-time and become an expert, but I want to have a solid foundation to do even more with it in Dynatrace after.
a very beginner start would be this youtube video made by Nana:
Kubernetes Crash Course for Absolute Beginners [NEW] - YouTube
She is a well known and established DevOps eng. started a while ago with courses online. most of which you will find for free. No certification here.
Regards
PS I do understand your way of thinking. When you do monitoring you expand on so many tech stack that to do quality thing you need to have good concepts and understanding.
Feel ya’
Hello.
the ideal option is to learn something - to start working with it. You need pet project that you will be deployed to own k8s cluster or EKS\ GKE.
If you have familiar with Terraform/Vagrant you can try to google “local Kubernetes cluster with Vagrant in 10 min”
Dynatrace can help with visibility and understanging how system works
Try to goolge “kubernetes learning path”.
If you want certification at the end → linux foundation → kcna\cka\ckad ←
Check out the free courses. A huge number of GCP/Azure/AWS study sites also offer basic information\free course about k8s.
From my colleagues, I know the way even easier. There are sites - playgrounds or sites with labs - nothing will have to be deployed on its own. More easier to start. But I recommend the hard way. You can also google: kuberenetes the hard way.
Alex Romanenkov
Hands on experience
trainings: youtube search: https://www.youtube.com/results?search_query=learn+kubernetes
Talk to admins in your company on best way to learn at your company.
I am still learning too
Also, sign up for this, tomorrow:
Observability Clinic: Mastering Kubernetes Resiliency with Dynatrace
Observability Clinic: Mastering Kubernetes Resiliency with Dynatrace | Dynatrace.
You can check that as a start, it contains multiple courses and labs.
Islam
I am signed up - good advice!
