I have multiple metrics and I want to combine those records into a pie chart in a Dashboard. How to achieve this with DQL using timeseries. Pie or Dougnut anything works. I am trying to combine the total value of timeseries Data like this
Is it possible by anyway to convert this to pie or doughnut visualisation where I want to see the total area of pie as total of metric1, metric2 and metirc3 and each slice represented in different colour.
Something like this.
For donut charts you need to have each metric in it’s own record. If you are using multiple different metrics the best way to achieve this is with append as seen below. To get the total to show in the middle, use the pie settings as seen on the right.
Otherwise, if it’s 1 metric but each section in the donut is a different dimension then this can be achieved just by splitting the metric as seen below.
