How to add ActiveGate info as dimension in 2.0
I am using {device.address} as a dimension. (as seen in the Rabbit  extension (-:wink: but this stays empty,
Who knows what the dimensions are when using AG,
KR Henk
Hey, i think i will need further details because I’am unsure what are you asking for.
device.address dimension is enriched from DataSource, it’s obtained when we provide either hostname or ip address in activation (monitoring configuration). It’s basically the machine which metrics are retrieved from.
And metrics from ActiveGate are not enriched with any additional dimensions, in OneAgent case they are.
