Hi Community,
We are exclusively using Private Locations (ActiveGates) for our Synthetic HTTP Monitors.
We have a requirement to route the synthetic traffic through a forward proxy. We are struggling to find a definitive answer in the documentation regarding the best practice for this specific setup.
Specifically, we are looking for a solution for one of the following scenarios:
- Per-Monitor Proxy: Is there a way to define a proxy configuration specifically for a single HTTP Monitor (e.g., for specific target domains)?
- Global Proxy for Synthetics: If per-monitor is not possible, how do we correctly configure the Private Location (ActiveGate) to route the HTTP Monitor traffic through a proxy?
Does the standard ActiveGate proxy configuration in custom.properties apply to the Synthetic engine’s traffic as well? If so, is there a specific syntax or flag required to ensure the HTTP checks utilize this proxy?
Any examples or references to the correct configuration would be greatly appreciated.
Thanks!
Per-monitor proxy (HTTP monitor): There’s no per-monitor proxy setting for HTTP monitors in the UI. The only per-monitor proxy override Dynatrace supports is for private Browser monitors via PAC file in the monitor script (and it overrides ActiveGate-level [synthetic] proxy).
Here link to documentation:
You can do workaround, like create separate Private Locations (different Synthetic-enabled ActiveGates) with different proxy configs and assign monitors accordingly.
Global proxy for Synthetics (Private Location / ActiveGate): Yes—configure it on the Synthetic-enabled ActiveGate in custom.properties using the [synthetic] section (this is the proxy “to the tested resource”, i.e., what your HTTP monitors hit).
Acording to documentation you can try something like this:
[synthetic]
proxy-server=proxy.xyz.local
proxy-port=8080
proxy-scheme=http
proxy-user=username
proxy-password=password
# optional: bypass proxy for specific hosts/domains
proxy-non-proxy-hosts=localhost|*.xyz.local
Then restart the ActiveGate service.
Does standard ActiveGate proxy in custom.properties apply to synthetics?
Yes—Synthetics has its own section: [synthetic] (tested resource). If you want the same proxy for both ActiveGate → Dynatrace communication and ActiveGate → tested resources, use [http.client] instead.
Link to documentation above
