How to create tabs in Dynatrace?
Please guide me on - how to create tabs in DT as per this article GitHub - dynatrace-oss/barista: Barista - the Dynatrace design system. Tailored to scale. · GitHub ?
Hi @Bharat1 ,
Could You please provide some more info about what and where You want to create?
Dynatrace have plenty of predefined views that aren’t or shouldn’t be editable. There are some specific areas where You can use/create custom view, like extensions. It’s hard to answer Your question without more details.
Bests
Michal
@Bharat1,
Currently, you can’t customize Dynatrace view. However, soon with AppEngine you’ll be able to create your own apps and data views. The link you’ve provided is our design system, which you can download from GitHub: GitHub - dynatrace-oss/barista: Barista - the Dynatrace design system. Tailored to scale. · GitHub in order to use it in your own applications and services to keep the UI and UX Dynatrace-style.
