how to enable filesystem monitoring? to monitor a file's size and modified time
how to enable filesystem monitoring? to monitor a file’s size and modified time
I would check the FileSystem Extension (you can find the detailed info on the Dynatrace Hub: Filesystem monitoring | Dynatrace Hub). It covers exactly your use case!
Hope it helps!
Thank you … under settings → general , i couldnt find Filesystem monitoring extention option  for my host … though i can find many other extensions.. Can you please help?
You’re welcome! You need to navigate to the Dynatrace Hub (Under Manage section on the left-hand menu).
In there, you can serach for FileSystem, and you will see the instruction to get it up and running.
can you please share a screenshot?
Sure! Here it is, with the search already made (FileSystem):
Under Manage, the first option.
