How to import Postman Collection into HTTP Monitor
Hello Community đꙂ
I’m looking for importing Postman Collection into HTTP Monitor.
Is there any way or tool to automate this ?
Maybe converting Postman Collection in HTTP monitor script ?
Thank you in advance.
Jean
Hi @JeanBlanc you can do some scripting or pre/post executions scripts in HTTP Monitors
May be is an approach for your goal.
Hi @JeanBlanc ,
I do not have idea for converting postman collection to http monitor.
But you can use to import http monitors via simple API calls or Monaco (also API calls, gitops way).
I would suggest to create manually one http monitor in DT and then donwload it with Monaco. Then you can use it as a template. In my case there were three http and one browser monitor in a test environment.
If you created your http monitoring collections based on the tempalate you can delpoy it with Monaco. From a test system I downloaded a sample collection of http monitors. In these test monitors I used different frequency, locations and simple gets.
I hope it helps.
Best regards,
Mizső
http_samples.zip (3.47 KB)
I don’t think there is anything yet.
Shouldn’t be to hard to write a small script that converts an exported postman collection into one/multiple HTTP monitors you can import via API though.
Thank you @MizsĹ‘, @DanielS & @pahofmann for your Synthetic Monitoring automation ideas :blush:
Maybe a future Dynatrace Extension for Postman đź’ˇ
Maybe an Idea to be requested.
As suggested by @dannemca : https://community.dynatrace.com/t5/Dynatrace-product-ideas/Import-Postman-Collection-into-HTTP-Monitor/idi-p/205834#M35667
Don’t hesitate to vote for it ! đꤗ
