When I do a simple DQL query on the spans, I can see some spans have exceptions like below. The exceptions are wrapped as records in an array under “span.events” field.
How do I write a DQL query to pick out spans with certain exceptions, for example “java.sql.BatchUpdateException”?
It looks like I should use “iAny”. However the example from DQL operators — Dynatrace Docs is only for simple type, not records.
Thanks!
"trace.id": "674367267460f48738534bff81e3718f",
"span.id": "f0a1bfa933cad913",
"start_time": "2024-09-16T09:13:09.991600000+10:00",
"end_time": "2024-09-16T09:13:59.999816000+10:00",
"span.parent_id": "f68ff88792574c09",
"duration": "50008216000",
"span.events": [
"span_event.name": "exception",
"exception.message": "Lock wait timeout exceeded; try restarting transaction",
"exception.type": "java.sql.BatchUpdateException",
"exception.id": "9d6064b5304e83f1",
"exception.escaped": true,
"exception.is_caused_by_root": true,
"exception.file.full": "SQLError.java",
"exception.line_number": "223",
"exception.stack_trace": "... ..."
"exception.caused_by_id": "50fe50882eeef674"
"exception.type": "com.mysql.cj.jdbc.exceptions.MySQLTransactionRollbackException",
"exception.id": "50fe50882eeef674",
"exception.escaped": false,
"exception.is_caused_by_root": false,
"exception.line_number": "124",
"dt.retain.size": "22598"
