Hello all,
Retrieving the properties via API for a container instance delivers:
<span>{</span>
<span>"entityId"</span><span>:</span> <span>"CONTAINER_GROUP_INSTANCE-08E89EB939BF5F49"</span><span>,</span>
<span>"type"</span><span>:</span> <span>"CONTAINER_GROUP_INSTANCE"</span><span>,</span>
<span>"displayName"</span><span>:</span> <span>"pega-web-55959b478c-dx8qw"</span><span>,</span>
<span>"properties"</span><span>:</span> <span>{</span>
<span>"metadata"</span><span>:</span> <span>[</span>
<span>{</span>
<span>"key"</span><span>:</span> <span>"KUBERNETES_NAMESPACE"</span><span>,</span>
<span>"value"</span><span>:</span> <span>"pega-cm02-dev01"</span>
<span>}</span><span>,</span>
<span>{</span>
<span>"key"</span><span>:</span> <span>"KUBERNETES_FULL_POD_NAME"</span><span>,</span>
<span>"value"</span><span>:</span> <span>"pega-web-55959b478c-dx8qw"</span>
<span>{</span>
<span>"key"</span><span>:</span> <span>"KUBERNETES_BASE_POD_NAME"</span><span>,</span>
<span>"value"</span><span>:</span> <span>"pega-web-*"</span>
<span>}</span>
<span>]</span>
<span>}</span>
<span>}</span>
Now I need to check for a text in the KUBERNETES_NAMESPACE value from the metadata in properties to do some auto tagging. What is the syntax for that?
This is as far as we got now: type(CONTAINER_GROUP_INSTANCE),…
Henri
