How to set up "FailedToRetrieveImagePullSecret" Alert for Kubernetes Cluster
Can someone help me understand how to setup alert for “FailedToRetrieveImagePullSecret” for Kubernetes Cluster?
Hi @Anjali
You can use a worklow with Davis Event trigger. I guess this is the most simple way.
Here is an example for a Backoff event (you can use it for FailedToRetrieveImagePullSecret).
I hope it helps.
Best regards,
János
Hi @Anjali,
Maybe it was a worng solution because in case of FailedToRetrieveImagePullSecret event.reason the event.provider is KUBERNETES_EVENT.
Could you please try this:
Best regards,
János
Hi @Mizső ,
Thanks for sharing, i will try to do this!
