how to show maximum value as a point?
Hello All,
Is that possible to show maximum value of specific measure as point in dashboard? You can see the sample picture in attachment below.If it is done, it will be perfect to serve details at the same dashboard.
Hi Murat,
Yes, you can for several metrics in Dynatrace. Edit the chart in which you wish to show the maximum value, and change the aggregation for the metric:
HTH,
Hayden
