I would like to use Dynatrace causation correlation feature as described below.
Davis® causal correlation analysis | Dynatrace Docs
I am unable to see ‘analysis’ as shown in link above.
Could someone guide?
Hi @vchandna what exactly is not working for you?
To select the appropriate time range for a particular graph, click on it and select the time you want to analyse.
R.
I don’t see the same ‘analyze’ option as shared in documentation ( Davis® causal correlation analysis | Dynatrace Docs). When I click on ‘Analyze Outliers’ it doesn’t seem to show Davis output
This features works only in the new unified analysis screens, so right now it is host screen, kubernetes, service or extensions based on EF2.
Thanks. Worked in new mode
You’re welcome :blush:
