# HTTP 302 for RuxitAgent
**URL:** <https://community.dynatrace.com/t/http-302-for-ruxitagent/44787>\
**Category:** Real User Monitoring\
**Tags:** real-user-monitoring-classic, application-detection\
**Created:** [March 21, 2024, 1:16pm UTC](https://community.dynatrace.com/t/http-302-for-ruxitagent/44787 "2024-03-21T13:16:44Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![josef\_solnicky](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/josef_solnicky/32/31968_2.png) [@josef\_solnicky](https://community.dynatrace.com/u/josef_solnicky)\
**Post date:** [March 21, 2024, 1:16pm UTC](https://community.dynatrace.com/t/http-302-for-ruxitagent/44787/1 "2024-03-21T13:16:44Z")
</div>
we are getting response code 302 for ruxitagent javascript. As result we are not getting any RUM data and cannot configure the application.
 ![302_ruxit.png](https://global.discourse-cdn.com/dynatrace/original/3X/a/b/ab287f3d0e669749966a8c248913e25ee16d083e.png)
Is there any trick/workaround how to get javascript correctly ?
BR, Josef
**Author:** ![michiel\_otten](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/michiel_otten/32/21987_2.png) [@michiel\_otten](https://community.dynatrace.com/u/michiel_otten)\
**Post date:** [March 21, 2024, 1:36pm UTC](https://community.dynatrace.com/t/http-302-for-ruxitagent/44787/2 "2024-03-21T13:36:54Z")
</div>
Hi there,
I think that the JavaScript agent cannot be found at the agent which mean that it is trying to place it on a location that is NOT available.&nbsp;
You could use a other location
 ![michiel_otten_1-1711028047147.png](https://global.discourse-cdn.com/dynatrace/original/2X/0/0788bb5a99e3c66618cc39f907c8910fd2b465ac.png)
You should check with administrators which path this needs to be. More information can be found here:
[Why don’t I see my applications or monitoring data? - Dynatrace Docs](https://docs.dynatrace.com/docs/platform-modules/digital-experience/web-applications/troubleshooting/why-dont-i-see-my-applications-or-monitoring-data#rum-trbl-javatagdwnload)
