In Custom Charts, it is possible to graph the connection time of an HTTP monitor, by using the following metric:
HTTP monitor - TCP connect time (by location) (Average)
In my case, the HTTP monitor does two TCP connections:
- First one is to the initial server, which then does a redirect to a different host
- Second one, where the HTML is produced
I’m not sure which value the custom metric represents, but given the latencies involved, I have made the following reasoning:
- As I have a very small latency for connection #1, and TCP connect time is high, it cannot be the time for the first connection
- Might be the time for the second connection
- or, it might be the sum for both connections
As I couldn’t find it in the documentation, does someone know if it’s #2 or #3?
