Hyper-V monitoring in Dynatrace
I saw a lot of articles about HyperV and Dynatace
What is a good way to monitor Hyper-V in Dynatrace :
  1. retrieve metric link
  2. Discover the cluster, link VM on it
WMi? How to? Which type of request? A plugin Scvmm? Where is it?
Thanks for your help
you can add Hyper-V via WMI with the new extensions 2.0,
Here is a link to the Hub with all: informatins https://www.dynatrace.com/hub/detail/microsoft-hyper-v-wmi/?query=Hyper
Hi pahofmann
i had seen this extension.
could you give more detail, about which requests to do ? results in a view DT cluster linked on node
may be a POC on a website
thx
There is no need to request it. Download link and documentation are right in the hub.
If you do not have a dynatrace instance yet you can use a free trial to test it!
