I/O commands queued on ESXi Host Alerts
Are there any recommendations to resolve these types of alerts? or Is there a way to disable the problem lift?
Hi Mauricio,
You can disable storage device alerts for ESXi hosts in Settings > Anomaly detection > Infrastructure > VMWare.
Sia
Hi Siavash,
Thanks for your help.
Just to confirm should I disable the 2 storage device options or should I just disable the second option that has modified values?
Forgive me but I need to be very precise with the customer.
Hi Sebastian,
If your problem alerts are specifically about commands queued you can simply disable “Detect undersized storage device”.
Sia
