our client has set of mobile apps created with help of Kony AppPlatform. The code is written in javascript, and then deployed to iOS and Android. Did anyone tried manual instrumentation for such platform?
Did you try to instrument the app manually? It worked seamlessly for most (android) apps I’ve tried.
I don’t have access to source code. Kony is JavaScript framework that can build application as native one. I think it would be better approach to check if it possible to inject RUM there but I think I’ll have to check it on some example app and my test environment.
Kony is currently not officially supported with Dynatrace. Based on some feedback we got over the last years, it seems people were successfully instrumenting it with Android and also on iOS. But I do not have any details and I also do not know which Kony versions were used.
Best regards,
Dominik
It is web framework so maybe some approach with rum will be the best.
I’m facing the same problem. Did you make it work?.
Johanna
Sorry, but Kony is still not supported - we made some effort in that direction but it did not work out, so there also is no support on the horizon.
