Integrating Dynatrace notification with Telegram
We want to integrate Dynatrace notifications with Telegram.
I think this can be done via Webhook.
I’ve seen this link Simple Ways to Setup Webhooks PostgreSQL Connection in Minutes in which it seems it’s possible to do that. But I have some questions about the implementation.
1.- On “Step1” on the link, it says that the first step in setting up Telegram Webhooks Integration is to obtain the Authorization Token.
So I guess we have to input that token clicking on “Creating basic authorization header”. Am I right?
2.- I have doubts about what is the Webhook URL that we have to configure.
Reading the link, on step 4 it seems we have to put the Telegram Bot API URL. And a Telegram Bot API must be created to send notifications. So I guess we have to put Telegram Bot API URL on Webhook URL field in Dynatrace. Is that the case?
3.- And about the payload,  I think it is clear this part for me: we should send the fields we want to be notified via Telegram. So, I have no doubts about this.
Has someone implemented that? Could someone help me?
Elena.
Hello @erh_inetum ,
actually ,you need to get familiar with how the bots work in telegram. This was always quite challenging to setup, but you can find guides for it. I don’t use telegram anymore, but this one below works for me.
URL is: https://api.telegram.org/bot**<your_bot_token>**/sendMessage
POST Method
JSON notification payload:
{ "chat_id": <your_chat_id>, "text": "<text_message>" }
Just replace:
  • <your_bot_token> with bot token
  • <chat_id> with the chat ID where you are about to send message to
  • <message> with the message text
Optionally you can send also markdown or HTML formatted messages, see telegram API docs.
I keep receiving an error, shown below… I am not sure what the issue is here… i have followed the above correctly and confirmed i have the correct token… and suggestions on how to resolve this?
"Custom Integration test failed
Reason: Could not connect to the specified URL"
Kishan
@Kishan are you using Dyntrace Managed or SaaS? With Managed most likely your outbound connections from the cluster nodes to the URL are not allowed.
It is a managed solution thank you… I have confirmed the firewall wasnt opened when requested.
