# Integration of Moogsoft and ServiceNow with Dynatrace
**URL:** <https://community.dynatrace.com/t/integration-of-moogsoft-and-servicenow-with-dynatrace/19049>\
**Category:** Automations\
**Tags:** servicenow\
**Created:** [January 10, 2019, 11:06am UTC](https://community.dynatrace.com/t/integration-of-moogsoft-and-servicenow-with-dynatrace/19049 "2019-01-10T11:06:14Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![siva\_puli\_exter](https://avatars.discourse-cdn.com/v4/letter/s/cdc98d/32.png) [@siva\_puli\_exter](https://community.dynatrace.com/u/siva_puli_exter)\
**Post date:** [January 10, 2019, 11:06am UTC](https://community.dynatrace.com/t/integration-of-moogsoft-and-servicenow-with-dynatrace/19049/1 "2019-01-10T11:06:14Z")
</div>
Hi
Could you please guide us on the below requirement?
We have got a new requirement to integrate MoogSoft and ServiceNow tools with Dynatrace.
Could you please provide us steps or any documentation?
Thanks&Regards
Siva
**Author:** ![skrystosik](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/skrystosik/32/21133_2.png) [@skrystosik](https://community.dynatrace.com/u/skrystosik)\
**Post date:** [January 10, 2019, 11:20am UTC](https://community.dynatrace.com/t/integration-of-moogsoft-and-servicenow-with-dynatrace/19049/2 "2019-01-10T11:20:39Z")
</div>
Here is doc for ServiceNow 🙂
[https://www.dynatrace.com/support/help/integration…](https://www.dynatrace.com/support/help/integrations/third-party/problem-notification/servicenow-integration/)
**Author:** ![pahofmann](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/pahofmann/32/17076_2.png) [@pahofmann](https://community.dynatrace.com/u/pahofmann)\
**Post date:** [January 10, 2019, 11:54am UTC](https://community.dynatrace.com/t/integration-of-moogsoft-and-servicenow-with-dynatrace/19049/3 "2019-01-10T11:54:07Z")
</div>
For Moogsoft you would most likely want to push problems from Dynatrace to Moogsoft, which should be possible via a custom webhook. You should check the Moogsoft documentation for that.
**Author:** ![larry\_roberts](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/larry_roberts/32/7131_2.png) [@larry\_roberts](https://community.dynatrace.com/u/larry_roberts)\
**Post date:** [January 10, 2019, 12:13pm UTC](https://community.dynatrace.com/t/integration-of-moogsoft-and-servicenow-with-dynatrace/19049/4 "2019-01-10T12:13:27Z")
</div>
Agreed. Pushing from Dynatrace to MoogSoft is the way to go. MoogSoft does have an out of the box integration on their side for Dynatrace, but all it’s doing is a query and you have to provide credentials. I am currently kicking the tires on MoogSoft and found that going from Dynatrace to MoogSoft is the best method. Hope that helps.
**Author:** ![jonno56](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/jonno56/32/13261_2.png) [@jonno56](https://community.dynatrace.com/u/jonno56)\
**Post date:** [May 9, 2019, 11:17pm UTC](https://community.dynatrace.com/t/integration-of-moogsoft-and-servicenow-with-dynatrace/19049/5 "2019-05-09T23:17:31Z")
</div>
Hi - when using the webook **from** Dynatrace, it is not possible to send the raw events… only a summary of the problem and the impacted entities that were there when the problem was first opened.
We have requested the RFE below for pushing events to any event management tooling - rather than being restricted to Service-Now ITOM module.
> **[Login | Dynatrace](https://sso.dynatrace.com/action/signin?goto=https%3A%2F%2Fsso.dynatrace.com%3A443%2Foauth2%2Fauthorize%2Fredirect%3FoAuth2CtxUuid%3Dec2ec9cc-3232-45f9-a854-48990c35aff0&oAuth2RedirectUri=https%3A%2F%2Fcommunity.dynatrace.com%2Fauth%2Foauth2callback)**
