Hi Team,
Dynatrace alerts when a process consumes high CPU/Memory, can we make Dynatrace ‘aware’ if this utilization is worth it e.g serving a long query? or due to some issue? and alert accordingly with different severity.
Hi Team,
When Dynatrace alerts, it will include the root cause. If it’s like Garbage Collection, it will probably mean “bad”, but it might be to a long query as you say, and the root cause will identify the query, which might be “not that bad”. Not all problems will have a root cause, but I can guarantee you that should be the first thing to look for…
