Is it possible to limit PurePath visibility ?
Customer has many applications developed by different 3rd party companies. Typically services from one application are called/used by other apps developed by another party.
Customer would like to share data for services between parties (operational/performance view). BUT don’t want to share detailed data from distributed traces (PurePath).
Is there any possibility to selectively hide detailed data ? Means e.g. - in “my” mgmt zone see all data including PurePaths and in “others” mgmt zones see just services/requests ??
Thx for tips :slightly_smiling_face:
Unfortunately not possible with the current permissions.
You can hide “sensitive” data via permissions on a management zone level. But you can’t differentiate between Service Level and PurePath level data.
You could add the relevant information to a custom dashboard and only share that dashboard.
And via the extended access definitions it is also not doable ?
AFAIK that’s only for settings (UI/API) and not UI Dashboards themselves. But I’d be happy to stand corrected if somebody has more input on that.
